Yeti’s Guild Ball WIP
Sicks
Scale75 is what popped into my head too, the steel metal and alchemy set comes with blue green and purple alchemy colours (as best I can tell they look like metallic colours but I'm unsure if there is a reason they are called alchemy and not metallic)
That said I find glazing colours over metallics tends to dull the metallic part down, perhaps your w&n medium will be enough or I know Vallejo do a metallic medium which could work too but I've never tried it, I am looking forward to seeing the result though
YetiSA
Thanks for the suggestions. Maenas, I'll look at those references.
Sadly I'm stuck with citadel paint for the moment as it's all that I can locally.
I've got quite a lot of painting done of the last day or so and made some good progress on Friday and Spigot.
I'm more or less done with most of the models. Still need to do Friday's hair, both pairs of eyes, the bottle and the glass... and of course the tartan. I'm going to do the hair now and then start on another model to give myself a rest from these two. I'm intending to pick them up again tomorrow and hopefully go along way towards finishing them off.
All in all I'm happier with Spigot than Friday. It might just be the fineness of her details but paint has been going onto Spigot more easily.
YetiSA
Bah, I decided to go ahead and paint the eyes and made a bit of a mess of it... like I normally do.
I was wondering if anyone here would be willing to impart a little advice. I'm fairly familiar with the principles but have serious problems with the mechanics, particularly with the dot. I find that I can put the brush down accurately enough but struggle to get the paint to actually come off it where I want it. The issue seems to be that with something so small I don't have any room to draw the brush and am trying to paint with the tip... which clearly doesn't work for me.
I have tried a variety of brushes, thick paint, thin paint, etc. but just can't get it right.
So what am I missing? How does one actually go about putting a tiny dot of paint exactly where you want it?
p.s. I have tried to paint the eyes before the face but didn't have much success... perhaps it's time to try that again.
ArchArad
You could try a toothpick. Or having slightly thicker paint - I'm talking straight-out-of-the-bottle thick.
YetiSA
The other day (while avoiding tartan) I decided to give the Brewer's mascot a lick of the brush and finished him in one sitting (don't think I've ever done that before).
He's a dear little kitten called Scum...
You can find some more angles in his gallery entry.
Yet another fantastic model to paint, with plenty of character. Unfortunately I made a bit of a mess of his right flank while applying the matte coat. The wind picked up as I was spraying from the last angle and to compensate I moved the can way too close to the figure and made quite a pool (really Bevan? really? you'd think I'd never sprayed before). Now I've had a bad experience with this before, back when I was young(er) and foolish(er) I put way too much onto my newest masterpiece and was horrified when it dried cloudy. I didn't want a repeat so I rushed inside to try and soak up the varnish while it was still wet... it... didn't work. I ended up peeling off a good chunk of varnish and the painter beneath it too. I would have been better off letting it dry and dealing with the frosting afterwards. I did some emergency repair work and had to repaint most of his right flank. The result wasn't bad but nowhere near the rest of the mini. :/
Ah well, you live you learn. You have to look pretty close to see the difference with the naked eye so I'm going to leave it.
While I had my camera out I decided to snap the team so far. All in all I'm pretty happy with them. :)
SaintToad
Yeah, that shot of the team looks very nice.
If you've got it, a think a shot of gloss medium on those nice big cat eyes would look really nice. Otherwise, maybe just a white reflection dot (which I might put under the gloss, anyway). I think it would make him look more alert and dangerous.
From an old and practised hand let me say now that there is no "Perfect" way to paint eyes without practise and control.
First off start with controlling your breathing, in the same way as when I was shooting releasing part of your breath before compleating the brush movement is essential.
Keep a steady position with both arms and hands supported, paint the eye closest to your dominant hand first, then move the figure to place the other eye closest to your dominant hand, not your hand to the figure. (Turning the figure upside down for this can help)
Things to remember about eyes:-
The pupil takes up approximately one third of the visible eye, but not all of you pupil is visible all the time, your upper eyelid will cover a small portion of the pupil. Leaving a thin white line under the pupil colour gives a realistic effect.
For tabletop mini's a black dot is more than enough, for competition colour is essential.
The Sclera (white) on a 28mm pupil painted white is too stark, use either an off white (VM Ivory or Pale Flesh).
In life the Sclera isn't always white, Race, Diet, health and geographical location can alter the Sclera from White through to a Yellowed tonality. This is most important while painting Busts as I've seen a beautiful Nubian face spoiled with pure white Sclera.
Align the eyes correctly, if a figure is pointing and facing down a weapon, paint the eyes looking at the direction the weapon is pointing.
(You'd be amazed at how simple a thing like that makes or brakes a paint job.)
Cats eyes as a vertical slit are not 100% vertical, they angle slightly so that the top is minutely closer together, than the bottom.
(The cat that has adopted us is staring at me as I type this, hence how I noticed.)
Dogs, Horses etc rarely show any white around the eyes except in fear or distress.
YetiSA
Thanks DR. Lots to think about and lots of practice in my future.
My particular problem at the moment it's getting the paint to actually come off the brush in a dot. It usually takes me several attempts before I actually leave any black paint on the mini (of course my previous attempts are always perfect). Again, a question of practice.
