Things left to do to this arm:
- Add stray armor plating to the upper arm and rivets all over.
- Add mechanical cabling going from the elbow area, as well as the back of the rippa (unfortunately, I\'m all out of lego cabling, so I\'m going to have to make a substitute from wire.
- Add detail to the gun area where it faces the torso (inner arm).
- Add a belt of ammunition that dangles for the machinegun ammunition port. I\'m not sure how I\'m going to make this, yet, but I\'ll keep thinking about it for now - I think I\'ll end up cutting some plastic tubing down into \'shells\', greenstuffing tips onto them, and using some floss or something that I coat in glue as the binding for it so that the belt is still flexible and movable - that way I can hang it correctly.
I meshed in the sides of the ammo clip just because I didn\'t like having the sides
completely open. The top shell is showing a little more than I\'d like, but they\'re all still removable at the moment so I will probably shave the 3rd shell down flat a little bit on one side so that all the shells shift down a little bit. I thought about extending the clip\'s size, but really, it\'s more of a slot where ammunition gets jammed, and logistically I don\'t want to bother with worrying about how many shots that things gets off anyway. I also don\'t want it going much more vertical than it is now because any higher and it\'d look awkward, in my opinion.
I haven\'t had as much time as I\'d like to work on this recently, but with my girlfriend going to a yankee game tomorrow with her sister and me all alone at home, I\'ll have plenty of working time.
