Man.
I just got back from some airbrushing adventures, and wow. That is one fickle beast to use, eh? Getting the mixture just right so that it comes out properly is more art than science, I think - I made a proper mess of pretty much everything I sprayed near, including the board, which I then tried to clean up.
Anyhow, I\'d started by drybrushing the buildings with a blackened fortress gray in the hopes I\'d see something fruitful, but it was too inconsistent and wasn\'t making me all that happy - the \'gradienting\' I wanted between the gray, concrete-dusted areas and the soil/mud was far too harsh with just drybrushing.
So, I whipped out the airbrush, and after a lot (and I mean a
lot of trial and error) got it to spit out a reasonable darkish gray color.
SOME FREE ADVICE: ETHANOL AIRBRUSH THINNER AND VALLEJO PAINTS DO NOT A HAPPY AIRBRUSH MAKE - it seemed to clump all of the pigment in the vallejo paint up, which subsequently jammed my airbrush up all nice. It took me a few tries to figure out what the hell was going on before I decided that the bottle of thinner I bought maybe wasn\'t helping me, and switched back to water. Blissful water. I\'ll never take you for granted in airbrushing again, even if you do dry slower.
It\'s odd, too, because on my test sprays earlier with a vallejo flesh color the thinner worked wonderfully, but it flat-out globbed the greys up.
So, of course, having a working airbrush I proceeded to go totally overboard on spraying the grays down. This was mostly because I got a bit over-triumphant and started spraying areas I know I shouldn\'t have touched with grays.
The good news, for what it\'s worth, is that I came to my senses shortly after, re-loaded the airbrush with scorched brown, and proceeded to use a wide-angle nozzle to roll the greys back a bit into the rubble piles.
Now, I\'m not going to lie - the browns and the greys are a bit harsh together at the moment because you\'re basically looking at completely unhighlighted soil on the ground - it still needs drybrushing to brighten it up properly, save for the muddy areas, which will bring it more in line with the brightness of the grey areas. I\'m also going to drybrush all of the grey areas with a lighter shade to hopefully pop out the details a bit, and I\'m thinking I may do a black ink wash over all of it as well - there\'s actually a bit of GW\'s roughcoat spray on the buildings at this point, as I put it on shortly before the initial black priming, which should help add a bit of surface detail.
I\'ve not yet figured out what I\'m doing with those busted-up floor tiles in terms of color.
Advice or recommendations appreciated, in any case. Think I\'ve ruined it yet? It\'s got a ways to go, in all fairness.
