Ok, well this isn\'t much of a blog post, but it\'s an indication of my success with my shortcut attempts!
Here are the problems I faced using silver undercoat:
1. Loss of details - metallic spray would be thicker in my mind
2. Gloss only available - getting the paint to stick
3. Affecting other paint going over it - enamel (shouldn\'t be an issue) and metallic (shining through)
So I have had success in all three areas!
1. Loss of detail - dulux silver is fine, just don\'t spray too much and it covers BETTER than white or black undercoat due to the paint pigmentation and it needs less paint
2. Add more detergent than I normally do to destroy the surface tension. This is only really necessary for the first couple of layers to get the paint something to adhere to
3. Inevitably this will have some bearing but at least it\'s a spray and I won\'t be getting as much cross contamination in the other paints. I\'ll just need to watch my layers, but it should actually work out better than normal because, being a spray, there\'s no chance of contaminating the wrong paint water and getting flecks in the opaque non metallic paints.
So it\'s all good and I\'ll be undercoating TONIGHT ready for painting tomorrow - I hope -
I still have a few details to add to the two newest vindicators, so I\'ll leave the undercoating of those for a little while until I get them totally finished.
And here\'s evidence of my success - not much going on yet, but you\'ll see more soon enough my fellow modelgamers!
