Shawn R. L.
@TAB - SUCESS!!! I finally got Photoshop to cooperate!! I will post the pic\'s mabey today or so and have some comments with them.
I\'ll try to post pics soon. In the mean time, what do I do when the primary lightsource is from directly above? For my mini the light source is sitting on top of the mini\'s head, so any \"secondary\" light source I guess ought to be from underneath if that makes any sense.Originally posted by Shawn R. L.
The primary isnt necessarily from above, yours is from teh front and low. The secoundary I usually have from above as normal.
Originally posted by vincegamer
The light source is very small, but I\'m not going to let that get in the way. Besides, in total darkness, if that were the only light it would seem quite bright to look directly at it.
It is a candle affixed to his helmet.
(Ever taken the end off a mag light? Sort of makes it like a very bright candle that way.) What I have done is gone into a dark room, put a maglight bulb just on top of the candle, and photographed him. I forgot the disk, so I\'ll have to post pics tomorrow.
An extremely bright light hits his head, shoulders, etc. At this point I have painted it black and then done a white highlight.
Do I need to carefully blend the highlighting at this stage? or is rough blending okay since I plan to cover it with color?
Originally posted by TAB Studio
Thank you Banshee :flip:
Shawn I copied the info and printed it out I will get started on it , Thank you as well for your time in this.
Okay, I\'ll try to take a better photo.
In the mean time, can you give me a suggestion as to how to paint the chainmail?
I\'m at a loss. Do I just do dark gray then lightly touch the top edges of the light areas white?
I am going to have a similar issue with the helmet - I\'ll try to provide an overhead and back shot.
Don\'t have a diffuser. That would then require me to get brighter lamps and becomes a sequence.
These pics were taken with 5 different light sources. Technically it could be considered 1. It\'s a floor lamp with 5 bulbs on the ends of 5 flexible pipes, so I arrange them basically in a 5-pointed star pattern with the camera in the center.
I\'ll try to take a pic of my photography set-up.
