Originally posted by funnymouth
i am having some trouble with red osl coming out pinkish (not nearly menacing enough for the undead). how do i fix this? i have heard adding yellow or orange helps - but wont that make it look orange?
@funnymouth - Look at the link below. I think the eyes have a fair amount of menace and might be good reference material. As I said below, have the rest of the mini be darker than the eyes.
First, paint the eyes and the area surrounding the eyes pure white. Blend the edges into whatever is there.
Next, think of a bullseye, the center being the actual light, in this case the eyes. Paint the eye itself and a bit of the surrounding area with a good bright cadmium yellow. Again, blend the outer edge. It dosent have to go all the way out to the very edge of the area you painted white. DONT mix white with it. I\'ll explain later.
Next, outline the eye with a good bright orange (think orange peel) and blend both inside and outside edges.
Now, this is where it really starts to scream. Get the absolute brightest red you can find (I use cadmium red) and outline the orange and go to the edge of where you have undrecoated white.
Go back now and put a fairly large dot in the center of each eye of pure white.
Look at the mini I posted below and see how you can have areas where the eyes have cast a glow on things around them. Do this in a DULLER warm color. Burnt sienna works well and on these areas it is ok to mix them with white. Not color but tone - light and darkness of the colors - have the lit areas match the background TONE or be lighter, not darker.
Why not mix white.....This has always puzzled me, why this works this way but I know it works anyway. If you paint a color over white you will get a very bright, vibrant look to that color. If you take the exact same color and the exact same white and mix them they will turn out pastel. You can see this on a tree leaf. If the sun is comming THROUGH the leaf there is a vibrant green but if I look at the same leaf from the other side the color will, in most cases, be duller. That\'s why the eyes you did were pinkish.
Try that stuff and post some WIP\'s. GOOD LUCK!!
@Mcclimbin - Seriously, is there much good Zin in Napa? Over here I think Dry Creek, Warm Springs and the Alexander Valley do some good Zin juice. Got any good brand names that arent too $$. I dont like em too dry.
OK, on to OSL - This link (the one below) is to a mini I did a while back that has OSL and dosent require a black background for the light to \'work\'. What I did is to take all the colors and dull them and darken them ONLY till they were darker than the eyes, which are the only place on the mini where I used pure white. That\'s one of the main trick\'s of OSL is that the light source MUST be the lightest - whitest - spot on the fig, even if only by a little bit.
This stuff might help explain what I mean -
One thing about OSL that is a bit of a trick is to understand tone. Some of the really mind blowing OSL (I\'m thinking of Eric\'s one with the blue fire) are done in pitch black. I have done it and it\'s a very dramatic effect. BUT pitch balck isnt necessarily the only way. There are shades/tone\'s/values of black. I can take a flashlight-torch that\'s a million candle power and turn it on at high noon outside. It IS pumping out alot of light. Because the ambient light is so bright you will get almost NO effect from the flashlight. If you were to aim it at something and take a picture every 30 minuets or so and look at them in sequence you would notice that FAR before total darkness the effect of the light would be visable. Look on a rainy or foggy day. You can see just fine BUT the car headlight\'s show up more and definately glow. That\'s because, while not black, the ambient light has been reduced to the point where the headlamps are putting out more light.
Take the mini you have and with some medium density washes simply put the colors you want into place. Dont shade or highlight. At this point you dont need to put in much detail, just fill in the areas.
http://www.coolminiornot.com/114300
