Hi Shawn Classroom #1 for OSL... TAB
SirJD
hi shawn,
thanks for your reply, im very excited with how he will turn out. Ill do what you said later today ( im \"supposed\" to be doing school work atm ;) ) and post WIPs later today/tomorrow.
thanks again
SirJD
SirJD
Hi again shawn,
here are the WIP pics, i have undercoated him and painted the panes of the lanter white. I used around 12 layers of thinned white paint to get it smooth.
SirJD
Sonnyslayer
loks like a gw miner.. one of the old ones.
im diggin thru my bitzbox in search of a good osl mini.. i will return... hoyvin moyvin
SirJD
Hi again shawn,
The miniature is from Games Workshop, it’s the miner champion from the miner command blister. The miniature has actually been undercoated black, so I’m not sure what you mean when you say wash it with black to get it really black?
SirJD
Shawn R. L.
Sir JD - On my monitor it looks like your mini is medium grey. Some of this process, being that it\'s done strictly throught text and pictures, is difficult to explain. I find that starting from black is simply an easier way to start. If you have alot of painting experience mabey we can skip that step.
SirJD
Hi again shawn,
looking at the pics i posted,it does look as if the mini is grey,sorry about that. I forgot to turn off the white balance on my camera which makes things brighter. if you want i can take afew darker pics so he looks as if he is undercoated black (which he is in real life).
looking forward to your reply,
SirJD
Shawn R. L.
The more accurate the pic\'s the better it goes. Could you put a link to your gallery so I can see what your painting levle is?
SirJD
@shawn: I took afew more pics and they look alot more accurate now, only problem is that photobucket is down so i cant post them :p. Sadly i havnt gotten around to uploading anything into my gallery apart from a LOTR mini i painted afew years back.
Let me know what you would like to do,
SirJD
SirJD
Hi again Shawn,
Photobuckets working again,so i posted the pics below. hopefully they show that he is undercoated black now :) (any bits that look greyish are just light on the mini)
Shawn R. L.
That looks better.
Simple question. How much painting experience have you had?
Referring to the OSL article - project where the light will hit from the lamp and paint those areas white. This time though, it dosent need to be as dense a coat of white.
provoke me
sorry for my lack of painting. schools starting soon and ive been using my free time to brush up on my math skills.
i hope to get some painting done tomarrow tho.
SirJD
hi shawn,
I have been painting for 3 years now,and i have painted on commission since august last year. i would say im a pretty good painter, ill try and post afew pics of some of my painted mini\'s soon so you can check them out. ill get to work on the dwarf and post WIPs in a day or so.
SirJD
Shawn R. L.
@provoke me - hey, there are more important things to attend to than painting little armymen.
@Sir JD - good to know. Try to project where the light will fall and then post a pic again........did you read the OSL article? If not, do.
SirJD
Hi shawn,
I have tried projecting where the light would fall, and painted the white accordingly. Ive posted the pics below, hopefully I got it right :)
SirJD
Shawn R. L.
Fantabulous! The top one already shines..............now, on the ax handle, the wirst of the glove, the shoe and any other area where the surface curves away from the lightsource, blend it - smooth the transition to black.
In the exact opposite direction of the light source(from side/below aiming up) imagine a moon light shining down from the other side, comming down at about a 45 degree angle. With blue with just a bit of white added. Now, cover your eyes if you dont like seeing naughty words ----------- drybrush. Drybrush on the dark side. Dont get too agressive at first. Keep the blue not too dark, not too light and drybrush enough that you can definately see it and it\'s contrast with the black. I know that\'s vague but this is one of the difficulties of doing this electronically which is one of the reasons I say to take it slow.
SirJD
@Shawn:Im all out of big piles of money sorry :)
PS: Im having a little trouble with blending the white to black, should i wet blend it or just highlight it but backwards? (white-black) ?
EDIT: No worries about the blending,ive worked out a way to do it, and it looks pretty good, ill post WIP pics tomorrow :)
