Sword&Sorcery
Coming along nicely! working with bigger scales helps a lot, it's easier to practice the different techniques because you have way more space than on regular 28/32 mm miniatures. At least it has helped me a lot to understand lots of things!
On the other hand you might be investing quite a lot more time on them, and they can become a bit overwhelming if you are not ready to face the challenge! So I would recommend having little other projects just in case....xD
Thanks, Maenas. Yes, the bigger scale is useful for learning but also a bit overwhelming and time-consuming, as you say. I think I'll add some 28mm minis into the mix. I need to practice at that small size if I'm ever going to get it right at that scale
