Okay Tommie, what's the next step?
Stew, I do agree with you, I think I overdo it with the undercoats. I think it's because I keep seeing these guys do nice even black undercoats, but with a white primer, most of the time I get a feckled, gray-white mini. What I end up doing is spraying a fine mist, taking a look, deciding it's not enough, then doing more sprays and end up doing too much. The fact that I have yet to find a proper, peaceful place to prime just adds to the problem. The local weather is nuts, my landlady doesn't want me spraying in the house, and my local shop won't let me prime in the back room. Dammit!
Talking about priming though... you say you turn the minis around... but if the mini is upright, the primer is essentially coming at the mini from a top-angle. My question is - do you lay the mini down prone to get some primer on the undersides?
Yuggoth, I'm surprised at how relaxing it is to get a mini painted to a good quality --- I think the relaxation is more on knowing that you are applying a proper technique. I wouldn't have thought 6-7 coats to result in such a nice coverage, I used to get impatient if I had to do more than 2-3 coats. Thanks for spotting that errant paint for me though! And yes, I am glad that Tommie has been kind enough to give me some help, as I am thankful to the active posters here for putting in their 2 cents every now and again. I learn bit by bit with every response, it's just that Tommie has decided to serve me with a more thorough tutorial
