Okie dokie:
I used the method I found at
Patrick Keith miniatures while searching on the internets. I had to go out and buy 22 gauge wire, even though I had 18.. but it's too big. I've yet to trim the arms, and the legs have a bit extra so I can put them on the sculpting jig.. thingy. I just made some rough shapes with the
Aves Apoxie this stuff is a 2 part epoxy putty like Greenstuff- but it's more clay-like and can be "watered down" slightly. Whereas GS has elasticity when pulled, apoxie will break, but it can be filed and sanded. Now that I think of it, milliput is the most clay-like of the 2 part putties I've used. But this has a longer drying time, so I find it better to use for different things at different times. As I said, was thinking about trying out
Super Sculpey but dunno- I'd maybe have to work on it for a long time before I bake it.
Well, that's about it.. but if everyone's showing off their toolkit:
Yep.. overkill. I may not use them all, but I think it helps to have a large array. From left to right: clay ribbons, mini silicone shapers, harbor freight's wax carver set (with a GW tool that is almost identical to one tool that comes in the set), large color shapers (which double as pastel shapers for art), three custom made tools (one made from a dead ball point pen tip with ball removed, a pin, and a shaped nail), two dental picks, and finally big cheap clay tools. I'll admit I had the sculpey in mind for the first and last sets. Eventually I'm going to make my own custom MLPonies from the clay and cast in resin. Well, that's it for me!
