TrystanGST
More water in the wet palette. That should stop the leeching. All paints will dry eventually, but even in my low humidity house, if I cover my wet palette with foil, paint will stay wet for a week or more.
*edit*
I think the base paints are a bit better at coverage than layer paints, but once you thin them it's all academic. So pick the color you like and go with it.
I don't know if that is what is happening - it just looks weird. I will try some other setups and see if that gives another result. I have also posted in the wet palette post in the painting section.
EDIT: might be the parchment so I just went and bought another brand/type and will do a test.
As you might expect, best to take what some staffer says with a pinch of salt when it concerns a product where they have a vested interest. Despite that, this might be normal for GW primer... but you can expect a lot better!
Anyway, depending a bit on where you are you should easily be able to find an alternative product (automotive primer or another type of spraycan primer from the DIY centre or hardware store) that's at least as good, but for less money, but more likely one that's better for less money.
Since you don't want to waste the rest of what you already have, there are a few things you can do to improve the way the primer goes down.
The first issue might be that you're spraying from a little too far away, which allows the droplets of primer to partly dry on the way to the model's surface; so try spraying with the can a little closer. Second thing is one of those things you'll hear everywhere when it comes to using stuff in a spraycan - make sure you shake it enough. That means shaking the heck out of of it for at least a minute or two, not 'a minute or two' (we've all done this believe me).
The last is to warm the can up a little, in hand-hot water. This might not make much difference if it's quite warm where you are currently but it's a good general tip, especially for colder parts of the year when priming can be more troublesome - when it's cold warming up the can could mean the difference between perfect results and unusably rough.
Decided to do something I have never done before and paint white! After less than a week I am trying white - never thought I would do that.
I tried but it turned out a bit more grayish - but it might be turn out great anyway. I also tried to paint some scratches etc. which I also haven't tried before
And I play to add glowing green eyes - yet another first
Feels like I am learning a lot even though the painting might not be anything special. Tips, pointers and ideas are more than welcome!
Thanks for the input. I will try that.
Really looking forward to painting the female sorceress - the detail is on the model is really great (and way higher than the models I have painted so far).
