Here are some photos of the genestealer I recently finished. It is based on my own base topper, which I painted as a super hot pipe, as if in some industrial location. Probably a space hulk, if you know me by now
I had a lot of fun with the osl on this one, even though I struggled at the start.
Then, following on with the stealth suit test piece from the previous post, I wanted to make a forest base.
Two reasons, first to test out my techniques for constructing trees, leaves and foilage, and second to make a nice base that I can possibly reuse in future.
The scene I plan involve a lake, with a little waterfal feeding a stream, that runs below some ancient stone ruins in a forest with large trees and ferns.
Here are two Tau units in the basic block out of the base:
I started by adding a wire frame tree:
and cut a bunch of leaves using a leaf punch. Then I used one of my ball modelling tools and a foam pad to give each leaf some shape before gluing it onto the tree with PVA.
I also made a little fern...
Here is the completed tree, after about 3 days of gluing
