Say Derek, thanks for your response and hard work. Can you tell those of us who are unsatisfied with the Goritsi bases what the options are for us? And if they are alternate bases can you post photos of such?
I was a bit confused about how the basing would work and after reading this thread, I'm a little overwhelmed. I don't mind a little work to make things look nice. But does anyone have any starter tips / links to read on how I should be approaching this? Not sure how the whole wood filler technique would work.. you just fill the base up completely with wood filler glue?? Seems odd.
I think we've had all of one person make a complaint related to a slapdash method. The big issue here is additional time spent for basing along with the cost and effort of additional supplies.For or all of you complaining that they didn't make the final bases clear, where does it say they were going to clear that with us. We are not board members in a company. I don't particularly like the bases that other companies have given me, but I've worked with them and my armies look fine. I think the argument that people who just want to play are going to have models that look silly because the bases have the lip and the mini is inside of it don't realize that most people who care are going to think the bases look silly because they are not flocked and finished. Just my $.02
It's worth pointing out that many of these minis have very small contact surface on their feet. The pegs are nice if your base can accommodate them.
I'm actually a big fan of these hollowed out bases. They make it really easy to apply one of my preferred quick basing methods:
Ingredients:
- sand and/or fine gravel
- terrain putty (I use cheap wood-fill or spackle, but any self-hardening putty works)
- some kind of sharp tool
- cup of water
- bases, models
This works best if you do large batches at once, makes the cleanup easier.
1) push a blob of putty into the hollow part of the base
2) dip it into your sand and/or manually push stones into the putty
3) use your tool on the surface a bit to make some texture
4) wet your model's feet and press them into the base to make an indent for the foot/peg
5) allow the bases to harden, then glue the models on
Selling my NOT-Goritsi inserts. Pm me. I am in Canada so could be a while till i get them.
So as I have said before I'm traditionally not a hobbyist, but I've delved into YouTube and chatted with friends and have decided when I get my stuff I'm going to tackle the bases. I bought cork to make rocks along with other ideas. Question is, I want to fill the base then put the cork on it. Should I just use the wood filler that someone mentioned or order some plywood bases small enough to just insert? I'm thinking the wood inserts would be really simple and quick. What size insert would fit without a gap, 20mm or 25mm? Thanks for anyone's thoughts. I'm actually pretty excited about this. My Hadross I'm going to experiment with some water stuff. Stretching in my modeling lol.
That's 40 minutes I could have spent doing something else (not to mention the trip to the hardware store), and compared to the 0 minutes I'd be spending with normal bases. It might sound petty to you but with my current schedule that's basically a whole day of hobby time down the drain. There are plenty of solutions, some easy some not, but all are more difficult than the default. That equates to bad design, simple as that. I really don't think you're offending anybody, but the fact that these require any extra effort simply makes them inferior. That's been my argument all along, nothing about ditching the game over it (in fact I very specifically mentioned it wasn't). I'm voicing my concern so maybe CMON might reconsider their prolonged use.Vax, I'm not sure that using a filler is as difficult as you make it out to be. If anyone has ever spread frosting it is the equivalent. It is also cleaned up with soap and water, and a good sized tub costs $5. There is no need to go near the inserts, making the money grab claim a little weak. As for time spent, doing a simple level application takes all of ten seconds, and that's being careful. This is probably no longer than getting an insert glued in. If you multiply that across that of the minis from the AK level you have fewer than 40 minutes devoted. Given how long painting takes, that amount of time is not that much for 220 applications.
i understand wishing that the bases were different. I agree that they were probably made for the new inserts, which was short sighted at best, and I don't love them, but they are hardly a reason to ditch a game. To make it out as difficult to overcome is also a bit unfair.
At this point we have pretty much covered the reasons people hate the bases, and I have offered up simple solutions that would cost little in time or money. For anyone new to this hobby, I hope you realize that there are some simple ways to deal with these bases that are easily done with little investment and not really tricky. For those who are angry, I apologize if I offend, and I hope you enjoy the game irregardless.
Not worth it. Its going to cost at least $15 bucks to mail it from Canada back to the US.just send them back as soon as you get them, the more people that ask for a refund the bigger message they will get about how people were unsaticfied with them. If you you sell them secondary they can pretend you were happy with them because you did not return them.
