The "fresh to the hobby guy" WIP book
giyomuSan
Guawol
Its a technique called zenithal priming. I do it with almost all my minis now. Your base coats should cover it up while still giving the coating a transition of lights and darks. So if you painted a red base coat you will end up with a dark, med, and light red right with just the base coat. It is also helpful by giving you a map of light and dark areas to work with when you are doing your shading of the model.
giyomuSan
@Guawol thanks for the explanation, I knew about zenithal but look to me this is most of the time being applied in all direction , less with directional source..but yeah process at the end do not differ much.
I started with the body of my wraith..not sure at the end ..the preshading made really add something haha..at least it kind of helped to place various tint.
Also used seriously that pk-pro putty i had..pretty cool stuff , this is mostly like using clay :D...and peel super easy. Handy stuff.
View attachment 69282View attachment 69283View attachment 69284View attachment 69285View attachment 69286
I stayed in a triad of yellow ochre mostly with some mix with dark blue grey for what should be the ost in shadow.
I will let it dry well and the rest of the details I will do using a good old brush :)..then will come those clothes !
giyomuSan
@Foxtail, @Guawol , thanks guy.
Little up, I redid the first one robe as it was overal more pale than the 3 others.
also base the slot, will need to redo a pass on those once i put the figure on those and base as well the minis too.
Now I am left with getting the weird spot on the robes, since the airbrushing was not perfect, so missed spot , not so good transition to try to soften xd, also couple highlight on some fold may be good
Once that done , i guess I can say I am finished with those.
View attachment 69450View attachment 69451
giyomuSan
@BloodAsMedium , thanks , yeah I try to keep them coming ( still plenty of minis waiting for me in my boxes )
@KruleBear, thanks, actually at first I wanted to go for more pale overall tone but it turn out as is :D
Well I am done with those guys finally , it have been fun to paint them and give me opportunity to fire up the airbrush for more than zenithal priming or base coat :D.. but still need some serious practice !
Getting those guys sit properly on the slots was a bit of a challenge , those are super tight..and you better look at the box to see who they arrange them cause with those robe clothes you can't really do what you want regarding which minis goes side by side each other !
Well once put in they are really sit firmly in the slot, however you better not remove them and put back too often or the paint of the mini base will likely to cheap off.
View attachment 69476View attachment 69477View attachment 69478
giyomuSan
I am done with the barbarian dude :D at least for paint, since it's been a while I did not touch putty / clay , I decided to make a custom base for him.
So simple 40mm MDF base and then sculpted a little base , also added couple elements for decoration.
After this dry I can then finish it for good :D
