If you set the blade up to cut on the pull it\'s rather hard to break the blade if you don\'t twist it around. If you do that and still break alot of blades then I dunno what to tell ya. :evil:
I use candle wax for saw lube. A cheap candle or tea light will last forever and a day. Might be a cheaper alternative to chapstick. You can also use bar soap for hand held small saws, anything large or really fast wont work well with bar soap.
Anyway, to the topic at hand, it depends how thick the base is and what, if anything, I want to keep afterwards. I hate integrated bases with a passion so I don\'t often have to deal with them. Usually just a pair of snippers followed by files or xacto knives.
To mini producers: please stop doing integrated bases! If the mini needs a base, cast it seperate, for the love of all things that don\'t aggrevate me! HAHA, teehee, carry on...
Edit: Holy moly, $25 US or more for those dikes (that sounds kinky), that is crazy, unless they can cut through a padlock or steering wheel column?
