Very nice, would you mind sharing what paints/washes you used?
Sure thing man
I work with a wet palette, I use citadel paints (and some p3) and I tend to just mix what colours I want.
I'l just give the obvious ones, if you want anymore info or it's not clear feel free to ask.
The pelegarth skin I thought looked slightly purple so I started by mixing Naggaroth night (purple) and black, then added a fair amount of white to get a light grey with a slight purple lean. Once I painted a layer of this I just added more white and highlighted the skin.
For the armour on the fel hammer I tried to copy the artwork, it's very dark but has a brown look to it which I though looked cool.
So I mixed mournfang brown and black for the base, probably 2 parts black to 1 part brown. Maybe less brown. Then I added a little mechanicus grey but I only highlighted the armour a little. I did take a thin brush and add a lot of grey into the mix to paint on some battle damage, scratches etc
I have never had much luck painting red so the Nasier are a good excuse to learn, red areas I started with wazdakka red with a touch of black, highlighted with wazdakka, then with wazdakka mixed with blood red, then final highlighted with blood red on its own. If I want a lighter highlight than that best tip I heard was add a touch of white and a touch of yellow. It stops the highlight going pink
The red is the only think I inked, I just use reikland fleshshade straight. I find a browner ink works well over the red
let me know if anything isn't clear
