Is it even average for the site? It is not.
Actually it is
Even with the negatively pointed 4.7 is about half-way (average) for a scoring of 1-10
I want to know what on the figs catches your eye.
You tell me, what specifically is dragging these figs down for you? What skill would you challenge me to work on next?
Atm there is nothing really that catches my eye. They are nice gaming minis that are more than "just paint 3 colors and done".
What could be improved:
- shades on metals, easiest to remedy with a dark wash
- lot of colors are patchy with the black under it visible. Mostly the reds, especially visible on the base edges. I'd say you need one or two more layers of the base color to start with a really opaque base. Also looks like you missed a few spots (on the crusader, the arm connections look like black)
- clean up surfaces with the base color after a wash: mostly visible on the crusader
- accuracy on colors, but you already noticed this. It really helps to take pics before sealing the minis. To be honest you can fix things even after that, then you'll have to reseal.
- prep work, dust and finger. Some missed prep work is especially visible on the crusader. Mouldline on the head and arm, some flaky thing on the left arm, where you scraped the mouldline off.
Dust: visible on the warjacks. Try to have a dedicated place for painting and clean it regularly (if painting takes over several days, then it also helps to cover them betwen sessions).
Finger: there are some whiteish spots on the edges of the warjacks, that I suspect come from handling and paint rubbing off. You could try getting a mini-holder to avoid touching it as much as possible.
- basing: ok this is a personal choice and I don't find it bad, but some might see it as too plain and reduce the score because of it.
Also you write being slow painter. That's not really a problem (unless you need everything painted for a game), but some things that may help:
- paint in batches, so same colors at the same time over a unit/battlegroup.
- use paints that cover well (less layers to paint for a solid base color). Usually P3/ArmyPainter/GW-Base/VallejoGame-Heavy colors are a good choice.
- Wash where you want it to be darker, not on the whole area (makes cleanup in next step easier), but don't get slowed down to be too accurate, the wash can slip and cover more than intended
- clean up after the wash with the base color. At this point it should already look decent.
- decide if you paint to play or display. If for play then a simple edge highlight is enough (maybe 1-2 layers of HL on clothes and such), if for display... well in that case time/speed will be totally irrelevant.
