Yellow rearing its ugly head in pics...
DaddyBrown
What's the best way to reduce the amount of yellow in any given pic ? I am a complete newbie to this photography malarky, so bare with me.
Cheers
*edit* I'm using a digital camera by the way.
Spacemunkie
Depends what you're talking about. Most of the time 'yellow' pics are caused by auto white balance doing a pug-ugly job under artificial lighting. Manually set the white balance, change your lighting or shoot RAW and correct in a RAW editor.
If it's just that the yellow channel is too saturated then you can often tweak the JPEG picture style and tone down inidividual colour channels. Easiest way is to shoot RAW and just drop the saturation of the yellow channel down in Camera RAW, DPP, Lightroom etc.
Scott;
You've mentioned RAW format so often I've started to try to use it.
Typically my Photoshop (CS2) doesn't recognise the NEF (Nikon format) any recomendations sugestions about available software which will allow capturing the NEF/RAW format prior to working on it.
Beelzebrush
Mike, I think there is an download for CS2 on the adobe website that updates RAW usability.
*edit* Just had a look and here it is...
Download list - http://www.adobe.com/support/downloads/product.jsp?product=39&platform=Windows
I'm guessing this is the latest - http://www.adobe.com/support/downloads/detail.jsp?ftpID=3587
Here's the supported camera list - http://www.adobe.com/products/photoshop/cameraraw.html
Hopefully, that helps.
I've got CS2 too. I wouldn't mind updating it to be honest but I can't really afford the price for PS's latest incarnation and other sources seem few and far between these days ;)
Spacemunkie
Unfortunately I don't think CS2 supports D300 Raw files. Adobe's Camera Raw update for the D300 came out when CS3 was around and they don't make them backwards compatible. It's a bugger having to upgrade Photoshop every time you get a new camera!
You can run all Raw files through Adobe DNG Converter (Adobe's Raw file format) and then process them in CS2 Camera Raw. You should have a Nikon Raw editor as well although I don't know how good it is. My choice would be to download the Lightroom 3 beta from here after signing up with Adobe:
http://labs.adobe.com/technologies/lightroom3/
I can do all my Raw editing in LR, then export to any of my other imaging apps with one click - Photoshop, Photomatix, a bunch of Nik apps, Noise Ninja etc. You can also set up batch processing and web exporting for large batches of files. I've got over 2tb of images now - must be nearing the 100k mark. As I download them from the card I keyword them so I can search by any of the keywords I've created or by metadata. Great for managing your photo library and makes finding stuff a little easier!
aon14
The most likely cause of yellowed pictures is lighting.
Not enough or tungsten.
So you want bags of real light or artifical sunlight light.
Alternatively you can manipulate the photos but I personally find that harder.
The simplest way to get great light is to step outside.
You will find full on sunlight out a cloudless sky is probably TOO bright though.
So you want a cloudy but still bright day.
Set your camera to cloudy setting.
Set up on the patio table or something similar.
If you live somewhere that's always very sunny then make a light box. Google it, there's loads of tutorials and it's easy.
Another option is a windowsill.
You need cloud to diffuse the light but you're indoors so it's more convenient.
You don't even necessarilly need a little tripod.
My camera needs to be slightly above the subject to autofocus - resting it on a magazine does that.
The magazine edge is where I placed my camera.
Result:
I used a sony cybershot camera.
Daylight is hard to beat in many ways, especially on cost :smile-big: But I wouldn't recommend you shoot under sunlight specifically, you want indirect light so a north-facing window would generally be ideal.
A bright but overcast day can be very good since the light is coming from the entire sky quite evenly, so it's much like the lovely bounced light used in a photographer's studio for many product pics.
If you don't shoot under overcast the light from the northern part of the sky is distinctly blue, so you may have literally the opposite problem to what you're currently having. If your camera can create a custom white point this will generally compensate for most of this, any remainder can be sorted in Photoshop, GIMP etc.
Beelzebrush
Daylight is hard to beat in many ways, especially on cost :smile-big: But I wouldn't recommend you shoot under sunlight specifically, you want indirect light so a south-facing window would generally be ideal.
I'd have thought a South facing window would be about as direct as you can get with sunlight (in the UK anyway). As the sun is at its height at midday in summer it is due south. You really want North light on an overcast but bright day.
Yes, you're right of course :doh: so I'll change my post above to save anyone getting confused.
Gwarh
It looks like it's been said before but my first thought was the yellowing was a result of the lights you are using.
And to try a "Tungsten" filter on the lense of your camera. If it's a SLR type camera (the kind you can remove and put on new lenses on, sorta the profesional grade type camera's). Then you should be able to buy a Tungsten filter from a camera shop pretty cheap.
If your camera is not a SLR and you can't buy filters for the lense, then like the others have suggested, take your mini's outside on a sunny day and shoot them with outdoor light. It will look great lighting wise.
SaintHax
I'd not recommend this filter. Any filter on your lens reduces your lens quality to that of the filter. It's far easier to set a custom WB on a dSLR camera.
Jeff_Little
I do something like that too except that I take my figure outside and use a piece of white sheet to defuse the sunlight and I use a "Graycard" as the background
