Worn White Leather
Freebootie
No one? I'm no great painter, but any painted surface that peels off, is going to do just that over time or in gameplay! If you want the look, to last. Then would not painting your base and then using one of the vehicle paint chip or worn surface coatings over it. Then spray your surface colour over it, in this case white, to then remove it in places (if you've totally covered it) or paint it on in the pattern that you require, and then remove it totally. Either way you do this, or by whatever method, you'll need to build this up with many layers to get the final effect that you require.
haucknathan
You ahould “deglaze” the leather—get rid of that finish—before you begin painting. This will help the paint to stick to the leather. You can buy jars of Skin Paint like acrylic Angelus.
