I've seen a suggestion to mix pigments in Isopropyl alcohol to get a good, powered/dust look. The alcohol gases off quickly leaving a comparatively stable pigment in a nice fine dusting. It worked great, and did a decent job of fixing the pigments in place.
However, one of the models I used got a bit of white haze on it from the Isopropyl alcohol:
Here you can see a successful pigmenting the model on the left and an unexpected haze from the model on the right.
What might cause this? Does anyone have any suggestions for removing it or avoid it in the future?
I did both models last night using to the best of my recollection, about the same amount of alcohol. The models themselves were probably painted at different times and might have had different varnishes (but both were probably touched last with Testors Dullcote.)
(I've googled and got a few hits about haze from Isopropyl on plastic, but mostly regard clear plastics and trying to clean car tail lights.)
