When does the unit influenced by Melisandre take the wounds? Before or after the test
bohms27
Melisandre creates a unique interaction when having one wound remaining on the unit I am influencing. If I use Melisandre to influence a unit, can I choose to take the panic test BEFORE taking the two wounds? Would passing that test, then allow me to play a card that triggers off passing a test, before taking the wounds? If yes, I could pass panic, play Baratheon Justice, heal 2, then take 2, without killing my unit.
Thank you!
CMON Michael Shinall
Administrator
The Wounds from her effect take place before the Panic Test.
If a unit had only two Wounds remaining, this would immediately trigger them being destroyed (which, in most cases, will make any preceding text irrelevant, unless you had an Ability/effect which would prevent said destruction, in which case the proceeding steps would be resolved and completed as usual).
