Volcanic Fury
Makhina
Shadrus Arikim from Nazier has an ability that adds dice to all his attacks as he gets hurt. The question is this:
Does each attack get the dice added BEFORE or AFTER the dice have been assigned?
If they are added after the dice are chosen then he could potentially attack up to three targets and each
Target would receive up to 4 dice on each attack. If a melee attack was chosen then each would generate an additional 4 die magic attack on each target(if they survived the melee)
If they are added before then he would be able to attack up to 6 targets at only 1 die per attack minimum.
Hence the question.
i find that the answer to this will probably affect how other models get their bonus, but picked this one as the biggest offender.
Mezegis
Nat is correct, they are assigned to the original, base attack. So if he has 3 wounds on him, his melee attack which is normally 3 would now be a 6. Please note: The extra 1 die magic attack does not gain any benefit from volcanic fury, or any other abilities. Whenever it reads: then the target suffers from a 1 die attack. Thats it, no adjustments or abilities are added to it because the model itself isn't causing that effect. Think of if like a burn or acid effect, it just happens with no outside tricks.
