MintFish
So a while back I came across this video on youtube:
http://www.youtube.com/watch?v=YnqSl5yyOMM
At around the 2:33 mark he demonstrates how to use automotive primer from a spray can in an airbrush by spraying directly into the cup and diluting with lacquer thinner. I'm unbelievably intrigued at the notion of doing this, but I'm also wary to try it because I can't seem to dig much info on this technique outside of the video itself. In theory I feel like it should work but at the same time I feel that the primer could just as easily dry in the cup before the thinner is applied and ruin a perfectly airbrush. If it does work, it could certainly go a long way towards improving the quality of my priming.
Has anyone on these forums tried this out? If so, what kind of results did you achieve? Are there more tutorials on this technique besides the one video I found?
