Talion
Hello,
Basically I\'m putting together a piece of software that I can use for role playing. Taking ideas from games such as \'Fallout 3\' and \'Oblivian\'.
Part of the design is a Strength to Encumberance ratio. The higher your strength value the more you can carry. I\'ve got it set up that as you pick up items, you will be able to see how much weight you can carry.
I reckon your average man should be able to carry around 20 - 30kg comfortably before becoming over-encumbered.
Anyway I\'m trying to work out the weight of various 40k weaponary and items. So anyone got any ideas on how heavy any items are?
I read that a Bolter shell is 0.8kg with each mag containing 30 shells - this can\'t be right as the mag alone would weigh 24kg.
Any assistance would be great.
