karpouzian
I'll let you know how it goes... A little scared, and the coats aren't the most even, but we'll see... I've heard some really good things!
That can make a huge difference, yes - loads of possible differences in formulation from one to the next, including the grain size(s) of the filler pigment and the toughness/hardness of the binder.count zero99uk said:Gesso is really good, ive had better results with black than white, but then it was a different companies, so it could have been that.
Most primers of this type are far, far too thick to use straight from the container (even the most fluid types of 'gesso' might benefit from a 50% addition of water and some would require being thinned 5:1 or even more). If you're getting any occlusion of detail you do of course need to thin whatever brand you have there, and apply it in multiple coats.karpouzian said:It has been about 10 hours or so, and there are some details still pretty obscured, and some clotting/wavy texture still... Dry to the touch, but I guess I'll give it a full 24 hours before I get really nitpicky... I did not thin it down (as I've seen some do not), but next batch I may try thinned...
Use a better primer; improve your technique; practice.karpouzian said:I have not mastered spray primers... Even the shortest burst of paint that has been shaken for 3 or 4 minutes doesn't turn out as well as I want...
The old mantra of two thin coats is better than one thick coat is true in so many contexts; you have to get used to the idea or live with the consequences.karpouzian said:...and I hate multiple coats...
Vallejo Airbrush Grey Primer .............just as good with a brush when you need to prime and its Precipitating down outside.Though I may try reaper or vallejo brush on primers, too...
Ok, chances are I have tried Pretty much every alternative priming method out there, I find that none are better than gesso. Maybe others people have diifrent requirements and like Mr Surfacer, or Vallejo or whatever. Thats fine-I'm just chiming in cause this thread Is about gesso, and I happen to have alot of experience with it, and I have a solid basis for comparison. This does not make anyone using Krylon or mr. Surfacer an idiot, i have gotten good results with both of those and more. I just come back to gesso through an airbrush because it's easier, not weather dependent (it very hard to prime in Arizona in the summerr, or on Guam at any time), and I can do it inside. Before I got an airbrush I was much more committed to Krylon (brushing on primer is the least efficient to me), but since getting an airbrush, gesso is king.
Yes if I scrape at a micro thin layer of gesso, it will come off more easily than Krylon or some others. But I have not found that it flakes off in the pairing process unless I am handling my miniature directly, and in fairness, so does Krylon in those cases. The reality is for gaming figures the gloss is the protection, and any ding that will get through the gloss, will go through whatever is underneath it. if my figures are for display, rough handling should not be an issue.
As far as detail obscuring, I find gesso, properly applied has the least amount of error, and because of its lesser adhesion, is more easily removed when inadvertently glommed on. It should b said that most painting I do, other than commission stuff, is in 6mm. If gesso can be applied and I can still find the monocle on a 6mm officer mini, then 28mmm cavernous relief should be fine. Maybe painting mega huge miniatures entails a different set of variables, but I have gesso primed and painted a Couple of titans, if anecdotal evidence matters.
Does this mean I think everyone should run out, get an airbrush, and spray prime with gesso (and use high end brushes, artist acrylics, and a wet palette-hehe)? Absolutely. Does this mean it's the only possible solution no. But hey, I am lazy and have jobs oter than painting to pay the bills, so anything that maximizes my painting time and helps make getting good results easier (and sometimes cheaper) I am all for it. But that's me, others swear by GW and don't feel exploited lol.
As with all kinds of acrylic-type paints, there's no need to wait for a full cure before applying further coats. If you're using a stiff brush and applying primer (or paint) to a textured surface it can be a good idea, but generally speaking touch-dry is sufficient for a subsequent coat not to disturb the first.Vishuss said:If [using multiple coats] do you wait for the first coat to "cure" (24 hours according to the bottle) before applying subsequent coats or do you just wait until the gesso appears dry?
You don't have to wait for natural drying, as quick-drying as acrylics it can be really handy to speed the process along using a hairdryer. I use this all the time when painting but it's most useful for me when priming hardboard, MDF or plywood, since I usually apply at least four and as many as eight or nine coats of 'gesso'... so there's no way I want to wait for it to dry naturally.Vishuss said:Any other tips you can think of?
