Transport: what's everybody using?
CaffeineBoy
I've owned (still do, in fact) Battlefoam bags for my WarmaHordes stuff, Sabol Army Transport(s), even a TableWar display case -- but none of them immediately leaps to mind as a WoK solution. I have probably 3 factions worth of stuff I'll eventually build up to battle strength, but they vary dramatically in size. Normal rank-n-file infantry is tiny next to the medium based stuff, big damn heroes (like Warchild), and the 80mm minis like the Fulung and Orsund.
So I'm looking for suggestions. What do you guys like/use?
hithero
WoK is a pain to pack due to the dynamic poses and huge sticky-out weapons, but I recommend trying the new design Games Workshop ones as their new foam will easily accommodate these models without the need to cut and enlarge foam pockets.
oistene
I use http://www.krmulticase.com/
The F-size trays are great for most infantry. They also deliver 'customisable' trays, where you can easily take out what you need. There are three kinds, I got J which works out nicely for the larger models. They are sturdy and relatively inexpensive, I cannot recommend them enough.
KR also have some 'eggshell' trays that fits everything at will, these will work well for plastics, since they'll stay put (unlike heavier minis). I use something similar for my Zombicide.
mordos
I use the toolbox/magnet method too. It works great and you can put so much more in the same space a foam takes. I am in the process of magnetizing all my minis. 1/4 X 1/8 is what I am using and depending on the size and weignt of the mini I use 1 or 2.
