Tough Color
Firespin
Alrighty, after about a year I\'ve picked up my brush and paints again. I decided to start be repainting my warhammer 40k tau army. Unfortunately, I\'m dead set on having their fatigues orange.
Little did I know that orange is extremely hard to paint, at least for me. I\'ve been testing it out on a few other minis and have not been having good results. I still get that awful basecoat-showing-through-the-paint-in-spots deal. I\'ve tried both black and white for basecoats, neither of them worked very well. I also tried building up from black with black to brown to dark red to red to orange. At red, however, it starts to get the same effect.
I need help. I\'d really like a good solid coat of orange with no splotches, but I need it to be done in relatively few steps, being that I have to paint an entire army in this manner and don\'t have an extraordinary amount of time.
Thanks for your help!
The practical problem that you\'re encountering is that the orange you\'re using is fairly transparent, which isn\'t unusual given that they tend to be made from a certain type of pigment and not something expensive like cadmiums.
I would suggest you might try undercoating the area in something like a sand or light earth colour as these tend to be fairly opaque and covering this adequately with the orange you have shouldn\'t be as difficult as white or black.
Amazon warrior
Orange is bloody difficult. I did some of my Dirz orange, and I used a dark red-orange with a touch of brown as a starting point. Then lots of layers adding in yellow to highlight. It was quite tricky to get it looking even half-way smooth, tho. This is what I managed:
Firespin
Alrighty, so I tried all of the above (except the flesh colored one which sounds pretty good) and I found that the best way to do it is white, then yellow and then orange. You can also put red down after the yellow and get a slightly darker orange, which is pretty neat. It takes two-ish coats to get a nice smooth color, but thats easily few enough steps to get the desired effect for a mass painting project.
Thanks for all your help.
