I have been having a devil of a time trying to use thinned VMC paints. I used to use GW paints and can get really good blends with them, and do alright with VMC but when I really try to apply thin layers, I can sometimes see the layer under what I\'m painting break apart under my brush. I give it plenty of time to dry, somtimes as much as 5 or even 10 min, and I know that you should be able to apply the paint before that so I don\'t know what I\'m doing wront. The paint is also well shaken too.
The thinness ration is probably 3 or 4 parts water to one part paint, and I wick off the excess before applying it to the miniature. I\'d like to only use water to thin, but I can solve a bit of problem with using a matte medium or glaze medium in my mix, but I would really like to use only water.
I\'ve tried searching the forums but can\'t seem to find the right keywords to come up with a solution.
Cheers
Cheers
