Yes, Minwax Polyshades is what you want. Despite what was mentioned earlier upthread, it is NOT waterbased. You need to thin and clean up with mineral spirits.This is from memory so it may be a little off...
Army Painter - Minwax Polyshades
Dark tone - Antique Walnut
Strong tone - Pecan finish
Soft tone - Classic Oak
Edit, I have used the Antique Walnut and like the effect, but it is dark so use extra bright colors.
I have also used Polyshades for it's intended purpose. I use a folded paper towel to clean out the channel on the top of the can after each use and have not had a problem sealing and opening the can. I also use a chunk of 2x4 between the lid and hammer to keep from deforming the lid. Finally, the large can of Polyshades at Walmart was half the price of the small can of AP at the FLGS. Of course, YMMV.FWIW, it might be just as economical to use the ArmyPainter. I bought a can of the Polyshades and got through about 20% of it before the can refused to seal shut anymore. Repeated opening and closing left a bunch of gunk on the rim and it wouldn't seal shut even with a hammer. So, you can buy a bigger can for the same price as a small can of ArmyPainter, but you may not get any more uses out of it than the small cans.
