Reaching out for help after many trail and error mistakes. Two things are killing me and causing more me headaches and mishaps, I have a Iwata Micron CM-C plus and using a smart jet compressor. This is the first airbrush I bought it's. So I'm still in learning phase with the airbrush, had it about 4 months. And I run scale 75 paints ( pick up the whole paint collection) and secret weapon's washes. And I don't know if it's me or airbrush or paints. But I am definitely not winning that's all I know.
Problems
the paint, every one I spoke too and all research I did scale came back one of highest recommended, and seeing what people were doing with the colors and what I have been able to do. I really like paints and would recommend them. But for the life of me I can't get them thinned right for my airbrush.
Should I add agitator to paint bottles, to help when shaking them up. Sometimes they run clear for few drops than the color comes. Is this normal? I often away for months on end for work. So they sit for untouched,
and if so what's good to use?
Some colors are thinner than others I found out. The ones in metal range, guessing that just nature of how the color was made? Or is it issue of no being mixed well by me.
I mix the paint 2 drop thiner 1 drop paint, in glass paint bottle's for colors i want to keep and use a lot of. And plastic shot glasses for temporary use colors. And use a brush to mix it, and sometimes the paint is too thick and Clumps up and other times it turns in to consistency of ink or glaze.
I been using scale thinner. Wanted to keep it all the same so there no brand compatibility issues.
Is there better method of doing this to get consistent results?
What is "right" consistency to use in that kinda of airbrush. The book says to run at 14psi so that's what been using. Is this optimal for scale paints? Or should I try a different psi level.
The airbrush kicks my ass all day long, I know there learning curve but I'm getting beat up.
Some times the paint comes out like fire hose all over the place others it fine mist that giving out even coats. But I just can't figure out the setting's on gun. Is there links to using this gun? I know right out the box I am not going to be achieving some of finest detail work out there. So going to ask some basic and stupid questions.
on back end of tube it had a adjustable knob from 0-4 which limits the needle movement. But how do the numbers effect the air and paint coming out? The higher the number the more paint coming out? I tried the numbers but seeing different effects each time.
the value in front of gun under the needle, what does it do and how is it used effectively.
The instructions in the book very vague and offered up nothing to help. They show lines that can be made but not explanation of how to achieve thin lines, transition to wider-lines and the stippling effect.
It's not all doom and gloom with some beginners luck I was able to get great results on test batch of 45 genesteelers. Blending 4 shades of grays all on all of them and come out to nice uniform blend. Was very happy with them. But had to leave for work for few months and now home on r&r and having no luck.
How is the scale Fantasy line? Are they all new colors? Worth adding to my collection?
thanks
Problems
thanks
