NiallCampbell said:
Btw, once I've used a batch of Dot4 can it be re-used to take off paint or does it lose some of it's potency?
I think you're good for a number of uses
at least, but keep it tightly covered as it'll absorb water from the air given the chance (and other ingredients are volatile and will evaporate).
The main active ingredient(s) in brake fluid in terms of its stripping power is hard to determine from the breakdown but if it has basically a solvent action it could last nearly indefinitely, most of the paint or primer settles out into a sludge on the bottom and there's not much left in solution.
NiallCampbell said:
Also slightly off topic...
Hey, it's your thread, hijack away!
NiallCampbell said:
...but I notice a lot of online tuts display techniques using a near fully assembled mini, what are your thoughts on this? I tend to try and paint each piece individually then glue together as I find detail work gets harder the more assembly is done before hand.
I think for most people this is a case-by-case thing. I like to paint in subassemblies nearly always, unless I foresee some problem gluing together at the end.
A simple figure, particularly in a pose where it could have been cast in a single piece, is pretty easy to paint after assembly. But sometimes the limbs, weapons etc. restrict access to the main body or even inside surfaces on the limb or weapon (and this can be major restriction in some cases, not just a slight hindrance). Not only can you not get a brush to anything you can see - despite the phrase that says otherwise - sometimes you really do want to get a brush to something at a particular angle to be able to paint it right, which is of course impossible if it's behind a shield for example.
