Special Rules
rrrray
So the Blitzkrieg box does not include any sort of reference for all of the special rules. I don't care for looking them up on the cards, so I made a reference sheet. Please note that this only includes the rules for Eastern Front, Blitzkrieg, and Jetpacker, because that's all I have. If someone would like to provide the rest of the rules, I'd be happy to add them to the reference sheet.
https://www.dropbox.com/s/m280f4x8pe0beic/Rivet Wars - Special Rules - Sheet1.pdf?dl=0 - PDF
https://www.dropbox.com/s/u71po0xmgwgrgya/Rivet Wars - Special Rules.xlsx?dl=0 - Spreadsheet, for those tinkerers out there...
https://www.dropbox.com/s/8sgpsmstbtubxai/Special Rules.pdf?dl=0 - And now that I took the time to play with the scenario template, this one looks quite a bit nicer.
rrrray
Also, if anyone would like to make this more attractive/thematic, I'd be thrilled! I tried to figure out how to do it in Decar's Scenario Editor, but I couldn't figure it out in the limited time I had available last night. I might give it another go, and if I do, I'll definitely update this.
Decar
This is neat; let me know if you had problems with the Template, I'll try and make it easier for next iteration!
Make sure you put it on BBG as well rrrray!
nitsuD
Thanks for this. I actually made an Excel sheet with all the stats so using your reference sheet with this will help me out. I like this spread sheet because it allows me to easily sort it by different columns and compare all the different units at a glance. There are 4 tabs at the bottom. 1 for all, 1 blight, 1 for the allies, and one for the neutral units. You'll need to actually download the file if you want to be able to sort it by the columns.
https://dl.dropboxusercontent.com/u/307826/RW STAT WORK.xlsx
rrrray
I'm pretty sure the problem was with the user, not the template. I was pretty tired, and didn't put a whole lot of effort into it. I hadn't used the Editor before either, so I might be doing something completely wrong. Do you have a tutorial up somewhere on that site of yours?
I'll upload to BGG tonight! Would have forgotten about that.
This is nice, nitsuD! I'm going to have to look at it a little deeper when I've got some time. Do you have every unit in there? It looks like it.
Decar
rrrray, it's pretty easy - there's just an RTF document you can pop open in word - if that's a fiddle I've also got a Word Template:
MS Word Scenario Template
I've got such a long list of things to get sorted on the site - youtube tutorials and such and links to lots of the new resources!
Once this weekend has passed I'm on the case!
rrrray
Thanks! I'll give this a try when I get home. Hopefully it'll work on the OS X version of Word...
nitsuD
Yep. It's every unit. I didn't know the correct unit types for the air units so those were just guesses. But everything else is just straight off the stat cards.
Decar
I've got my work mac with me tonight, so I'll give it a go now - any problems I'll post another update or save it in another format!
Decar
I can make it A1 if you need a large sheet!
Glad you got the template sorted, it looks really good!
