Lucus Aurelius
Simultaneous Actions – Rulebook Page 21:
Situations may arise where both players wish to trigger an effect or play a card at the same time, or multiple effects would trigger simultaneously. When this happens, they are resolved in the following order:
• If all effects are controlled by the same player, they may choose the order in which they resolve. • If the effects are controlled by different players, the player whose turn it is will have first opportunity to trigger their effect. If they choose not to activate any effects, then their opponent will get the opportunity to activate their effects. Once the player whose turn it is passes to their opponent, they may not then respond with their effects. They have given up their chance to do so!
• Once both players have declared any effects they wish to trigger, those effects will then be resolved, beginning with the player whose turn it is resolving their effect first, followed by their opponent.
Example: It is Player A’s turn and they have an ability with the trigger After this unit completes a Melee Attack. Player B has a Tactics card with the trigger After an enemy unit completes a Melee Attack. Player A declares the use of their ability. Player B, upon seeing this, decides to use their card. Player A resolves their ability which allows them to retreat from combat. Player A then completes their retreat action. Upon completing their retreat action, Player A decides to declare an Order with the trigger After this unit completes a Retreat Action.
Question: Which resolves first, Player B’s card that was declared after the Melee Attack Action or Player A’s Order declared after the Retreat Action?
