crazedloon
After a few games vs Shael Han leaves me with a few questions.
Can a model change defensive enlightenment between attacks in the same combined activation?
Can a model select a defensive enlightenment when a reactive ability targets the models, such as counter attack?
Does the Winterhawk actually produce infinite attacks with its inspire? As written it provides an attack after every attack, should that be an attack after every attack action?
How does the Winterhawks defensive aura seem balanced vs every other equivalent ability? The Zaalak for instance requires a test vs every model in range (at a lower will stat) and is a specialist, other equivalents require much more restrictive situations.
Do the Dragon Legionnaires get to check for healing vapors for each hit generated or 1 time per attack (no matter the number of hits) does this also apply for Hong Yao's infernal Fortitude?
