Oh yeah, I could definitely see Brienne being a good choice for that scenario or two where the commander unit gets marked out anyway. I’ll have to remember that. Though I forget if determining the scenario comes after you’ve built your list already. I think it does.
Outside of those particular scenarios though, I actually think your 40pt list there would do better with Bronn than my 35 pt I was running him in. You have 3 NCUs and I only have 2, so you’re in a better position to actually get the coin bag. I found with only two NCUs, I’m way more likely to target the tactics, free attack, or maneuver zones over the coin. So going forward, I probably won’t take Bronn in these smaller games I’ve been playing...
I actually like your list a lot. Most people dump the stag knights, but I find them pretty fun, esp with Stannis in them. You’re right, it doesn’t have much room for revision, but here’s an option that could be fun:
- Stannis in a warden unit
- stag knights with Daario
- second warden unit with Bronn
- Cutthroats with storm crow Lt.
- same 3 NCUs
Thoughts:
Daario Stags on the charge or with tactics cards could be gross. Imagine being down to 1 rank and then playing “Hold the Line” on them combined with Daario’s order. 11 dice on 2’s with Crit Blow and Sundering, 6’s are double hits no saves. Yeesh. That enemy is probably dead. Could be cool...
Then you’ve got Bronn to add a little speed and aggression to the wardens, and the cutthroats with the Lt. will get nine 3+ dice with vicious and sundering at full ranks. Yea, you have to control the bag for these goodies to work, but with 3 NCUs and Florent, it should be doable a fair amount of the time when you really need it. Shyra makes for the ideal bag-grabber.
So this list isn’t too different model-wise but it trades a little defense on the loss of the excellent master wardens and the Sentinels/cutthroats swap, in order to boost offensive capabilties across the board. As Stannis is the more aggressive commander, this makes sense to me, but I’m just messing around with ideas for the fun of it.
