Scumbling?
MoblinMan
I came across a technique I have never heard of today, though there was no description as to what it actually entailed.
I'm all curious now, can anyone explain to me what Scumbling is?
This was part of the item description for the Broken City mat on Zuzzys site (Advertised on the home page of CoolMini atm):
We recommend using acrylic paints applied in thin layers using wash, dry-brush and scumbling techniques.
MoblinMan
Nevermind, I managed to find my own answer:
Scumbling is a painting or color technique where light, opaque colors are placed in thin layers over darker colors to create a softening effect.
So basically it the same as, or similar to glazing I guess?
In Chigh P.I.
Wow, ive not heard that term for many a year! And i certainly never expected to ever hear it in relation to the hobby!
I only know the term as an old interior decorating technique, where one uses 2 paints of different medium to 'play against' each other (for want of a better description) to create a rather interesting effect.
Not sure if this is what the author of this particular piece meant, but i imagine its quite similar.
Im now extremely interested to see if anyone else here has more info on this. Thread bookmarked!!!
DarkStar
Scumbling is a painters technique where you apply a typically thin layer of paint on top of dried paint, then rub enough of the fresh paint off after it's applied to leave a residue behind.
Haven't seen that term used in mini or even terrain painting before, but I actually do use that technique during weathering sometimes. Never thought of it as scumbling per se, but it is what it is.
I would paint something like a rusty metal color, then when it's dried I would paint over that with the color of paint that I want to look like a chipped paint effect, say, yellow, then I would wait a bit for the paint to set up just a little and take a soft sponge and rub off the yellow paint. What this does is leave behind the yellow paint in the recesses, where naturally it wouldn't have rubbed off due to wear and the environment over time. That sort of thing.
That's the way the oil painting books I have describe Scumbling, the two I checked agree that it's similar to Sgraffito, except you don't scratch at the paint to remove it, but simply rub at it. Now, on the web you'll read a few variations of the technique, where scumbling is like our drybrushing almost, except you use thick dry paint and just trough it on and use a palette knife to spread it over a layer of dried paint...or I've seen it described as a glaze type of affair.
At this point I would say it's one of those techniques that means something different to many people. I was always taught that it was applying paint, then rubbing it away leaving it's residue behind.
Google image results have some images of the various ways people use this, that should help understand it's uses.
MoblinMan
Interesting, it seems you learn somthing new everyday.
I think I'm inclined to agree, I've read a few varying and very different explainations my self now. On another note, the site I mentioned above, actually does explain the technique afterall (They have a tutorial section I missed). In his demonstration he seems to dabble watered down paint on the mat in irregular patterns, to give a marbled effect.
