Sculpting on a flat surface
Djonma
I\'m not sure how to explain what I think I need to do, so I\'ll just go for it, and see if people understand!
I want to sculpt something that will sit on a flat surface on a land raider. It\'s going to be a Mark of Tzeentch (slightly more elaborate than simple outline), to go on the bit where I\'ve removed the Imperial Eagle.
However, I want to build the base of it, which will mostly be just the external shape, and then when that\'s cured, add bits to it and sculpt a bit, so it gets the detail I want.
Now, in store, and I\'m sure somewhere here (but I just got my pc back after a couple of months without and so can\'t find my way through my favourites!), I\'ve seen staff members sculpting flat things like banners and reliefs on blisters.
Now, I could do that, lay it all down on a blister. My main question is; how the heck do I get it off the blister and on to the landraider after it\'s all cured properly?
I guess it\'d be like rolling a ball of green stuff / milliput mix (I\'ve decided to start using a mix), then squishing it flat, and cutting out the base shape. Then leaving that shape on the blister, and building up the mark as I need it to be until it\'s ready.
It\'s after that that I\'m confused about!
Thanks!
Nicola
QuietiManes
Or you could do it on wax paper or plastic wrap (on something flat), they\'ll just peel off afterwards. Tin foil or paper is another option, paper just rubs off if you wet it, if it sticks and wont peel off. Tin foil tends to be problematic with the sticking, mostly due to its tendance to tear, leaving little bits with no edges to grab to pull off. But anywhooo...g\'luck
Djonma
Fab, I just bought a huge roll of cling film!
For the kitchen of course, but in this house, anything can end up being used in a gaming way :)
Nicola
SJB
If you sculpt it straight on to the blister plastic you can just peel it off once it\'s cured. Greenstuff will stick to plastic enough to stay put but it can be pulled away fairly easily.
Djonma
It\'s going to be a mix of greenstuff and milliput terracotta though, which is why I was really unsure about straight onto blister.
Nicola
Shawn R. L.
If it\'s not too thin, put your putty on a plastic or metal surface - vinyl is really good. Not much sticks well to it. When the piece is cured, if it\'s thick, you can just take a palette knife and just CAREFULLY pry it off. If your piece is thin, wait till it\'s almost cured and pry it off. Then put it on a flat surface to cure totally.
Nicola
that should make it nice and hard and all the better for prying off, just peel back the blister
Djonma
Dim question... what\'s a palette knife?
I only have the stupid knife end of the crafting tool GW sell so far.
Trip to B&Q this week will result in a proper stanley knife I think.
Is that the kind of thing I need?
I have some wax sculpting tools for the sculpting / modelling, a ton of files (though they always wander...) and a new treat to myself, an almost dremel with a whole ton of extra attachments.
That\'s been a lot of fun to play with!
Though I don\'t know what all the attachments do yet, I\'m just hoping the drill works into metal properly (it\'s not a proper dremel as they\'re really expensive, but a cheaper mini rotary drill). I really want to have a go at magnetising things.
Hopefully I\'ll come up with a sketch of the tzeentch mark tomorrow and then maybe even start it tomorrow. All depends on how my hand is really, though I can sketch with my right hand, but I don\'t want to try to do any sculpting with only one hand available, bit hard to hold things.
I don\'t even have a vice or anything...
Nicola
mickc22
Granddad!
Hi Nicola,
this is a Palette knife, although it seems they are called a painting knife these days :rolleyes:
http://www.greatart.co.uk/JAXPAINTINGKNIVES-palette-knives.htm
Originally posted by mickc22
Hi Nicola,
kids nowadays eh mick?
put some cling film down first, and sculpt it on top of that
Winner! This is the simplest way of doing it in my experience.
Any kind of sheet plastic will probably do actually - I\'ve used plastic shopping bags, small bags from computer equipment, acetate - long as it\'s bendy enough to peel from the cured putty without stressing the sculpt too much. But Cling Film is great because it\'s so ultra-thin and flexible.
Forgot to mention, if you want to sculpt on a blister like this nearly any putty will get slightly more flexible when heated with a hairdryer - should pop right off the surface with only a little gentle coaxing.
You can remove putty from glass jars and 35mm film canisters using a quick heating too, if you find a need to use either as a former (making shields for example).
D
donga666
What a good idea!!! I never thought about that.
I\'m off to find some jars and stuff with the correct curve now :D
Djonma
We don\'t have thrift stores over here.
However, a quick glance at the argos website shows they do a cheapie for £3.89. That\'ll do :)
Nicola
Nicola
yeah we do, although they are rare. a cheap 2nd hand job would work
