Sculpting Chains
Dark Lord
Hi.
I have just crossed the line into sculpting minis from just doing conversions and I have a question.
Does anyone have a good method for sculpting chain? I\'m having quite a rough time with it.
I\'m looking at minis with chains and I can\'t tell if the sculptor has made a rope and then carved it out of the rope, or made tiny individual piece and placed them together.
This is the effect I want to achieve.
Thanks
PegaZus
Stealth Freak
I really want to believe that this was a topic not more than a month ago, but the only thing I can find is this topic on using real chains.
In the topic I\'m thinking of, there was a link to a tutorial on how to do chains with GS. Just wanted to chime in, to rattle someone with a better memory than I.
Jericho
Consummate Brushlicker
For doing that type of Chains I recommend doing it in 2 stages, especially early on. For starters, do the
shape first. Keep it flat. Then add little ovals once it\'s had time to cure. When I was sculpting early on I\'d have a lot of trouble trying to do everything at once, so I started to sculpt the slow way and do everything in stages. If you mess up, you can smudge off your greenstuff and still have it half finished :D
DaN
There\'s a great tutorial on the US GW site...
Someone else found it a while ago... Can\'t remember who :p
http://us2.test.games-workshop.com/games/40k/darkangels/painting/successor_characters/orteza_tut.htm
QuietiManes
Both of those methods would seem to make getting the bottom side of the chain sculpted quite difficult. I remember a tutorial I saw quite some time ago, although I can\'t find it now, but I can list the general idea easily enough, since at the time I thought it was quite similar to the method of carving wooden chains. Anyway, this may make more sense if you use the pictures with the other tutorials to visualize what I\'m trying to say, here it is:
1> Roll out a thin sausage of putty, make it into a long thin square rod shape.
2> Let it cure up and harden a bit.
3> Look at the end, divide it into 9 squares, cut the 4 corner squares away down the length of the putty. So you are left with a long \"t\" or \"x\" or \"+\" type of shape.
Note: It may be easier to just sculpt the \"t\" shape initially after mixing the putty, in essence doing steps 1-3 in one go. Although probably difficult for anyone without alot of sculpting experience, like me. You could perhaps make a long strip about the width and thickness of the chain links, then lay a long thin sausage on top of it, smooth it out and then repeat on the bottom? The bonus for this effort is the links will be rounded on the outer edges and less work to fiddle with later on I guess. Anyway, moving on.
4> Let it cure a bit more. If need be.
5> Cut out little triangles all down one side, then offset on the next ridge, then repeat for the other two ridges. Make sure to match up the triangles you cut away on the opposite sides. Or you could just pinch the sides like in the other tutorials above type of thing.
6> Lastly add the finishing touches, clean up the edges, sculpt some indents where the hole in the chains would be, etc.
This will leave you with a solid core down the center but it will look fairly decent when painted up, viewable from all sides/angles. Much like the chain the goblin is swinging around.
