1) Can Windblast move a model diaganol?
2)Do you pick up exploration tokens if windblast moves you over one?
3)What happens if you kill a hero while they are resting?
4)Can you defend while resting?
5)In the final scenario of the main campaign, can you use a ranged attack from outside the locked door once you have achieved accumulating the six coins, or must you be in the throne room to use range attacks?
6)Does using a portal count as two moves if you are moving onto it from another space. For example you need to move one space to move into the portal space and another to use the portal.
7)Do enemies that have ranged attacks (heroes included) that are attacked using a ranged attack, get a payback attack with their ranged weapon? For example Greensleeves attacks a goblin archer from three spaces away. Does the goblin archer get a payback attack?
8) In the Rookery the topmost right corner and bottommost left corner have Hammer Beastmen in them in a room without doors or open spaces. Is this a misprint? How do you enter the room since it has no doors or open spaces?
Thanks in advance for answering these questions we came up with after our first campaign.
Regards,
Joe
Regards,
Joe
