Morticanis
I'm seeing a lot of people post on FB about this, and I'm not sure what to believe.
From my reading of the rules, I believe that when determining a RANGED ATTACK the sequence of events is,
Pretty straight forward.
Here's the rub - based upon the way the rules are written, the 2nd and 3rd points of the sequence imply that you must have range and LOS prior to the shift...and the last point invalidates the first three...as follows:
Ranged Attack:
• Ranged Attacks may not be performed while engaged. (Not relevant to this discussion)
• A unit must have a Ranged Attack, and a viable target within their maximum range (including after their shift, see below). By saying "Including after their shift", the implication is that they must have it PRIOR TO their shift, and maintain it afterwards
• When a unit performs a Ranged Attack, it may first shift up to 2”, so long as, at the end of that shift, a viable target is still within their maximum range and Line of Sight. Again by adding the stipulation that the target is "still within..." again implies that the target must start off that way in order to be valid.
• Once this shift is completed, the unit will then select 1 enemy unit in Line of Sight and within range of its Ranged Attack and resolve an attack against that enemy. This implies that targeting occurs AFTER the shift...which refutes the wording of the 2nd and 3rd lines.
My assumption is that, unlike "Charge" which has a very specific sequence requirement, the requirements for ranged are determined after the shift - due to line 4. And, if so, the 2nd and 3rd lines should be edited to reflect that. And based upon that, the actual sequence should be:
What is the actual answer?
M.
- "Determine if the target is in range and line of sight"
- Perform a shift (If desired)
- Fire
Ranged Attack:
- Shift
- Fire
M.
