Questions about Fueled by Slaughter (dest. Def.) & Block-Ability (Presc.) ???
Tabris*
I search in the official FAQ and some Forums but did not find any conclusion for the following questions of our gaming groupe ...
  • Did Fueled by Slaughter (FbS) activate after the Defender is completly destroyed ? ... I argue that the trigger for FbS is "After this unit completes a Melee Attack", so when the trigger for FbS take place the the Defender is already removed from play so no destroyed rank is on the table.
  • Which attacks can ignore / bypass the blocks-ability (like Shieldwall ...) ? ... Can Precision-Attacks be blocked and if not why ( a 6 on attacks will hit and a hit can blocked ) ?
please help and give some tips why or where I can find it, Thanks ... a lone yes or no will help little ;)
Hecaton
I would say that a destroyed unit, by implication, has lost all of its ranks - otherwise it wouldn't be destroyed.
Shield Wall only works when you're being attacked, and only blocks hits. Effects which inflict Wounds (like Precision, or a dragon or Savage Giant's melee attack) cannot be stopped by Shield Wall. Also, effects which inflict hits but are not attacks, like Counterstrike or Hold the Line, cannot be stopped by Shield Wall. So just keep in mind - am I being attacked? Is this inflicting hits? Then Shield Wall (or Hardened, or Resilient) applies, even if those hits cannot be normally blocked with defense dice (like Mag the Mighty).
Valenae
There is nothing in Fueled by Slaughter that requires Defender to stay alive at end of attack. So you will heal 4 wounds.
