Pastor Prime
Hello,
Been a while since I\'ve posted, very busy. Anyway I have a couple of questions about resin figs as I\'ve never worked with them. I read that it is possible to heat and bend the pieces, how extreme can you get with this?
I want to turn the head on a resin figure (28mm) and flatten out his back as if he is leaning against a wall. Would it be possible to heat the head and neck area and twist it a bit? Would it be possible to heat the figure and smoosh it against something flat to flatten the back? Would I need to worry about the model getting fingerprints moulded into it when it\'s heated?
Thanks for your help, don\'t know if this is getting TOO crazy with resin.
- Q
- Q
