M
McAnally
I\'m seeking any tips and techniques anyone may have for spraying primers and sealants in high humidty areas. I\'ve followed lots of tips in regards to distance/shaking well etc but am still having issues with my primers and sealants. The two types of primers and sealants I\'ve used are GW and Krylon.
I believe the problem with my primer may be that the humidity causes it to clump due to moisture in the air clumping the spray before it hits the mini. I\'ve also wondered whether or not the temperature outside will affect the mini/sprays as well. It\'s very warm here as well as a with a high humidty. I\'ve wondered if I were to cool the can and the mini if it would help..or if it might explode (in the case of the can).
My sealant problem consists of milky coverage..both with GW and Krylon, though less so with Krylon.
Please believe me when I say I\'ve tried several tips in regards to making sure I\'m far enough away or close enough to the minis while spraying..even to the point of using a measuring tape. Also, I do not have a basement to spray in, they\'re just not feasable where I live. (salt marsh area in case anyone is wondering )
I\'d appreciate any tips or ideas ya\'ll can come up with as it\'s getting very frustrating to spend hours painting a mini only to have it look like I did it in five minutes.
Thanks all
Sheri Mc
Thanks all
Sheri Mc
