yeah a second vote for r+c. super cheap and great quality. similar to the w+n series 7's but they don't have as much springI recommend Rosemary and Co, to be found here:http://www.rosemaryandco.com/. The brushes are superb and I have no issue buying online form them because they have good quality control. Best bang for your buck and they are very helpful if you have nay questions.
EDIT: Oh and its the Series 33s or 22s you would be after.
Kolinsky is a particular type of hair. Sables are a related species and sable brushes can be good too, and are usually cheaper, but tend not to be quite as good at holding a sharp point and have less spring (springiness, resistance to bending). Synthetic brushes often have very good spring, but their points let them down and the bristles don't have as good capillary action.-Ice said:Okay, I just got confused. Apparently, "Reaper" is the brand name (who makes the brush), Kolinsky is the material used in teh brush... is that right?
well when you push the wet bristles, they stay over in that direction a bit more than the w+n which come back. less shape memory if you willfreak, what do you mean about "spring"?
Not sure if this is mostly the brush but you may be pressing too hard as well, just something to bear in mind.-Ice said:I do like the GW fine detail brush but all I can comfortably do with them is the Space Marine shoulder armor ridge. The point is nice, but tends to splay out when I paint.
Unfortunately this varies. This is why Dick Blick have started to list the sizes of the brush heads to give people buying online a better comparative idea from brand to brand.-Ice said:Anyway, in relation to the GW fine detail brush, how big/small is a 0 and a 1 compared to it?
You might want to check back on some older threads about this - lots of us recommend using larger brushes than you might think because of the tendency of our type of paint to dry so quickly in a teeny brush. And the needle-sharp tip of a quality brush is worth using if you're paying for it.-Ice said:At the moment, I'm looking for a fine-tip, short bristle brush on the theory that shorter bristles bend less and would be ideal for fine detail work (such as highlighting the eagle on the space marine bolter) and won't bend as much to my heavy-handedness.
You have to be shitting me Tommie...
I'd not rule out SOME of the GW brushes though; the Drybrush and Stippling brushes are decent value for money and designed specifically for those roles.Thanks for the help guys! I do understand the risks of buying online and a few of you have pointed out some online shops. Can anyone actually vouch for any of these shops in terms of quality and return policy? Surely there are others here who buy online. I'd like to hear from those people.
Ken Bromley is walking distance from where I live. (Ok an hours walk or 10 minutes in the car.) They are very helpful and despite the fact that the brushes are kept in a STAFF ONLY section usually invite me to check on the brushes I'm buying. Recently ALL the W&N series 7's I've bought there have been of improved quality than the suspect ones of a couple of years ago.
One concern I have is brush terminology. I've never seen a 000, 0, 1, or 2 brush before, all I've dealt with so far are GW brushes.
OK simple description
000 = Fine Detail Brush
00 = Detail brushes
0 = Standard Brush
1 = Basecoat Brush (but with W&N has greated detail capacity).
2 = Large Brush
Since differing companies have differing size within the 0, 1, 2 categories that's hard to define.
Is a brush labelled 000 the same as a brush labelled 3/0?
YES
I've seen some companies sell a 6/0 brush, how insanely tiny is that?
They are mostly aimed at Watercolour Miniature painting (on paper) and while the idea of smaller brush = better control, what it means is that with the acrylics paints we use the amount of working time before the paint dries on the brush is miniscule. And Yes I've fallen into that trap myself and still have a couple of 10/0 brushes.
http://www.artsupplies.co.uk/ is the company he founded.Ok, "who" is Ken Bromley?
