problem watching miniature mentor video.
jdmchaos
hey gang,
when i watch the downloaded video they play butthe video will freeze while the vocal
part keeps going.when this happens i push pause and then play and it starts playing again,but then freezes again a couple of minutes if not seconds later.
can anyone tell me whats wrong or having the same problem?
i am using the vlc player they tell you to use.the only other one that i could use is quicktime.i dont want to down load it cause i dont like quicktime.HELP PLEASE...
Tercha
Hi, This sounds like a bandwidth problem to me, try pausing at the start, then play once the whole video is downloaded. Alternatively turn off everything else that may be using the connection such as limewire, msn, itunes, etc
falela
What kind of hardware does your PC has?
The video is in HD, so requires a moderate spec to watch without any hiccup.
EDIT: Oh, what you described is what happen when I watch it in my notebook. I have to watch mine in my desktop which has much better hardware
jdmchaos
well this is happening to video that has been downloaded already.i watch some of the other ones with no problems.it seems to be the most recent ones,dreadknought conversion,barbarian,festus.
i have 3gigs of ram,and 500 harddrive,and nvidea 120.87 i believe its 1 half gig.
is that what you mean?also i just tryed quicktime player and still problems.so i believe something is wrong on my end.HELPPPP.
ScottRadom
Shogun of Saskatchewan
Well... I'd give Quicktime a shot. I have zero issues using quicktime. No hesitiation, and none of the non synched vocals either.
falela
Don't know what nvidia 120.87 is, but still, I think your hardware is probably fine. Probably software issue, try playing it in GOM player and see if the problem persists.
TAB Studio
Nvidia came out with a new driver you may wish to update I had a few conflicts till I did and I notice considerable improvement
miniaturementor
Miniature Mentor HD video playback
Hi Everyone,
the choppy playback issue is directly related to the computer's performance - it could be the CPU or the hard drive or both. HD files require a pretty powerful computer to playback the content smoothly - it's not like youtube or vimeo where the deccompression of the video is done on the server side. Our videos are downloaded to your hard drive which requires that your CPU handle the decompression. The benefit of this is that you get 30fps video, better quality and the ability to adjust sharpness and color.
to solve the problem try the following...
1. Use VLC - it's much faster than Quicktime.
2. Defragment your hard drive and make sure there is at least 20% - 30% free. Delete or move older stuff you don't need.
3. Turn off everything else including antivirus, pop-up killers, instant messaging, itunes, any automatic updaters and anything that starts unneccesarily. You can check the net to see how to do this. But remember to delete your history, cookies and cache after using the net because tracking cookies will reinstall themselves while browsing.
4. Make sure you are running off your main hard drive, not an external one.
5. Open the video, press play, then pause, and let it sit for about 5 mins to cache - then try to watch it. If that doesn't work, try reducing the size to 50%.
6. If your using a laptop make sure it's plugged in.
Best,
Support Team.
jdmchaos
i understand what your saying miniature-m,but most of all the other video's work fine on my com.downloaded the gom player and they play fine.thank you falela.glade i didnt have to buy a new computer to watch them.thanks to all the cmon helpers on this post.
dshavers
So like everyone else, I'm having issues with the latest addition for Miniature Mentor. Likely because it's in HD format, as I am able to play the other videos just fine. I did find a workaround for those that still want to use VLC. I'm on a Mac so my only real option is to use VLC. Just my opinion since Miniature Mentor is reading this thread is to possibly offer HD as an option for those that can't or have trouble playing those type of videos.
* Open the preferences
* Tick "ALL" in the lower right corner <----------------------- UPDATED for v1.0.1
* Go to "Input/Codec"
* Go to "other codecs" subcategory
* Go to "FFmpeg"
* Put the "skip-filter for H264" to all or Non-ref
* Restart VLC
This should at least get the video playing. Hope it works for everyone.
Gadzooks
If you burn them to DVD or even just convert to dvd and then play them it will work without the choppiness or the stuttering speach.
