Pens and/or Pencils for outlining my cuts, scalpel for cutting after I have drawn the lines.
If I need straight lines and exact measures I use a slide caliper to measure out the distance needed and then I use it as a scribe to groove out the outline of the piece I need.
When the line is done I use a ruler and a Stanley knife to cut following the groove.
One thing I never do(unless the piece is really small or bent, then I just cut it out straight away) is cut all the way through the plasticard, I cut about halfway and then snap the pieces.
That helps making harder lines with a smaller risk of failing due to uneven pressure from your side when cutting(Makes the knife think it's an ice skater or something, hurts both you and the pieces I tell you!).
When bending the plasticard I roll al larger piece than the one I need around the handle of a sculpting tool to soften it and then carefully cutting out the shape I want with a scalpel in the now softer material.
Files are constantly used to adjust angles, edges and such and I'm using a toothbrush to remove excess chippings.
Oh, and when I need to scribe freehands I use various sculpting tools, the edges on those are lovely for freehand work.
Plastic cement is the way to go with plasticard, super glue is in my opinion good for making mockups to see if the pieces fit or if I -really- need that piece now and cannot wait 3 minutes for the glue to set.
