Originally posted by tring
Ok, I\'ve had a look through those and some on other forums :innocent:. I think I will use Simple Green but has anyone else stripped an armorcast model? ???
EDIT: Ok, so the model I\'m looking at has black primer and I\'ve read Simple Green isn\'t man enough for the job. I live in the UK so alot of things people suggest isn\'t available over here what should I use?
what do you want, a prize?!!Originally posted by Avelorn
Moved it here.
Lye = caustic soda if you want to go to straight for the active ingredient. Be very careful how you use this stuff, follow the instructions carefully and wear rubber gloves and eye protection.Originally posted by tring
So Lye is a chemical that I need to look out for. I thought all Oven cleaners were scented though.
Moved it here.
Originally posted by Einion
As mentioned, there are plenty of threads on stripping paint - a search would have given you all the info you could possibly want on the subject!
If you want to stick to oven cleaners on this side of the pond Mr. Muscle oven cleaner is the one to look for.
yack, acetone does dissolve some resins so you\'d be much safer using something like oven cleaner (Mr. Muscle or Easy-Off, depending on where you are). Best to do a small test first though, just to be sure.
Ah, good news! I\'ve just ordered some from the UK and have been wondering about its efficacy and toxicity.Originally posted by Donga
I\'ve also used \'Fairy-Power spray\' its like Dettol but quicker (1/2 - 1 hour).
Both safe on resin and both purchased from my local Tescos! No gloves, no nasty fumes, clean mini. Cheap too!
EinionSkin contact: Prolonged exposure may cause mild to moderate skin irritation.
Ingestion: Possible mild to moderate gastro-intestinal irritation with nausea and vomiting.
Inhalation: Inhaling aerosolized product may cause mild to moderate irritation of the respiratory system.
