OSL Effect
chrisbruk
Hi,
I tried searching the forum but could not find anything on how to create a good OSL effect.
So, I appreciate that this is more of a practice thing and careful airbrush control, but does anyone have any hints/tips/advice on how to achieve this? Any help will be appreciated (and this is gonna be my first time, on a Stormlord).
Thanks,
CB
PegaZus
Stealth Freak
There's also the Sticky Thread here, and in it is a link to Shawn R. L. 's article here on CMON. He's also been known to help out, so he might drop in to give some pointers at some point. The only sticking point I can see is that you'll be using an airbrush. Hopefully the same general concepts carry through to both ways.
chrisbruk
Thanks, will take a look.
I assumed that an airbrush would be the ideal tool (for tank lighting)? Will read the threads and articles, then the only way to find out is to try :eek:)
cheers
CB
PegaZus
Stealth Freak
cheers
CB
Yeah, see, I didn't know how big a model you were trying to paint. Tanks would be an airbrush job for sure (IMO). Wizard holding an orb? Might be better done with a brush.
And notice that if you invoke Shawn's name, he appears? Just don't say it three times in a mirror. I'm sure you'll wind up owing beer and pizza and a flight home.
the alleycat
as far as i'm aware, airbrushes are always a pretty good cheat so long as you can effectively spray from where the light would emanate.
A lot of poeple are using airbrushes to do it
A lot of people are spraying at an area to light it
A lot of these attempts look not so awesome.
Shawn's guide is excellent though a little confusing to my somewhat lacklustre brain :)
PegaZus
Stealth Freak
Honestly, I like the effect you've done. My mind had to adjust to it (go to night). I think the red light in the middle needs a bit more balancing, as it seems to be mostly on the left.
The yellows... might need some spreading out. I'm sure columnar lighting could have been there, but it needs to diffuse a bit more around the edges.
However... I've done OSL maybe twice, so don't run with my advice until someone else has added more.
chrisbruk
Thanks - see what you mean on balancing the red (being left handed I always pull to the left!)
Was in 2 minds on the lighting - whether to go column or diffused. Think I will lightly try a lighter yellow on the edges to diffuse more, and perhaps a more golden in the middle.
Thanks for the feedback - all good stuff.
chrisbruk
Nice article, the guy shows his examples very well with computer graphics - have a Valkyrie to build, so will apply some of this logic to the cockpit crew etc.
cheers
CB
the alleycat
What did you have a hard time with? Maybe I can do a better job of explaining myself.
More likely a 'me' thing than a 'you' thing, think it's more that i haven't tried to put it into practise. I think i understood the principle, but the principle seems to be based on classical idea representing sunshine and stuff... and i start to struggle to make it translate into the 'glow' effect we see more of in mini painting... if you see what i mean.
In simple terms, it's a great overview, but doesn't help me understand how light would act if a part of the mini itself was glowing or shedding light in some way.
Note: it's a great guide, just my brain struggles to translate the principles across. The one i linked it good for the glowing idea but skips over my key uncertainty which is, how to know what lies in the path of the light... and would this change based on how diffused the light/light source would be.
No critisism intended :)
Shawn R. L.
@chrisbruk -
Here's a quick re-do of what you have now. I hope you can see things clearly enough.
One important principal in most any OSL project is to keep in mind that the color of the light being cast. When whatever color you choose is used, make sure to combine the color of the lit area and the color of the light. Your blue tank with yellow lights - blue +yellow= green, red + blue = purple etc........... You will most likely need to add a little white...or a lot and make the cone of light (the area the light is falling on) a lighter tone as it gets closer to the lightsource.
The area of the cone of light will do a shift. The closer to the lightsource, the more it will lean towards that color. in the case of your tank, it will be more yellow and lighter. As it gets further from the lightsource it will shift towards blue green and will be darker.........as in closer to what the base of blue is....NOT darker than.
1. If possible, when doing a glowing object, it really helps to try to darken what's surrounding the lightsource.
2. Make the actual light source PURE white. Yellow's one of the few you can do this with.
3. Highlight a narrow area around the light source with a saturated yellow.........keep it narrow.
4. As the light gets further from the lightsource, the edge of the 'cone of light' gets softer. It starts sharp and quickly becomes blurry.
5. Anything that the light will cross will have a cast shadow. Easy way to do this on larger parts is to use, in this case, the blue you've already painted the model. It's tempting to
want to make this area dark. Keep it just the same (light and dark wise) as the rest of the model.
6. Fairly quickly the light will 'run out of gas' and what's left of the cast cone of light will simply, and subtly be the base color with a touch of yellow added.
7. Make the entire cone of light be a COMBINATION of your base color AND the color of the light. If you don't do this the light source will simply look like the source of sprayed
Yellow paint.
chrisbruk
Thanks Shawn, that is excellent and does make sense and explains it very clearly.
I think my paint mixing/airbrush skills will let me down but will spend some time on the weekend (work gets in the way!!) and apply what you have written/shown.
Thanks again, really do appreciate it (and everyone else's help too)
CB
