need help
fredwinu
i dont know what to do next, got one of those \'converters block\' thingies... any ideas for bits/ parts plus things i may (most likely) have missed
thank you.....
Ogrebane
Big assed engine. Smoke stack. Fire smoke flames. I would also put it on a base and maybe shorten the left arm if you are going to use it for gaming. Gaurenteed to break of in its firts game trust me.
Looks good so far
fredwinu
lol it has a normal chaos engine but it aint stuck on as i was thinking of making some ammo crates, too hard tho... loving the idea of the smoke stack...
plus i dont think it\'ll break as its pinned with 1.5mm rods.... industiral strength glue..
thanks for the advice...
very cool. iagree with the others about the engine and smoke stack. for the base though, make sure that you have hundreds of spent casings on the ground. make it look like he is pumping those bullets out
fredwinu
ha ha ha i think i feel my next diorama comming on, hot tub scene...
also loving the idea of the used bullet case\'s i\'ll definatly be doing that, now i have insperation to continue on with this 2 year old convertion... thanks guys....
OrkyDave
Some sort of roll- cage around the marine would definatley look veeeeery cool (thing the loading suit in aliens and the big kick arse battlesuit thingies in the matrix 3- neochrist superstar...)
Looks like a fantastic start though, hope you get enough ideas to help finish it!
fat zombie
I agree with the statement about the arm. It looks cool, but it will come off.
It\'s one of those APUs, isn\'t it? Than I say yes, power pack on the back, roll cage and lots of bullet casings.
In fact, give it LOTS of armour. You can never have too much.
marineboy
Shorter arm is a must....far too long and gangly, too little strength out at the very end. A warmachine has to be durable and easy to fix on the battlefield, too many joints make too many points that can break.
And a biiiig engine...and the hottub.lol
vincegamer
Personally I think it looks way off balance. I\'d correct that by giving the right arm an enormous claw to add weight without adding length.
Of course if you shorten the other arm it may not be necessary.
