My first mini, that isn't a mini, but it's kinda mini
Palantirion
Hello. My first post on this forum, and my first "mini". Technically this is a plastic model kit, but in roughly 1/144 scale it's the same size as mini figs and the same painting techniques are appropriate. Is is mecha? armor? a mini figure? Yes!
I most often paint on canvas (and two cars), but have been expanding my skill sets into model kits, GKs, figure repair and now minis. I really enjoyed the relatively small scale in terms of workload and session length. There was a lot more flexibility that enabled me to be more productive with less stress than with larger projects.
As this is my first mini I look forward to hearing feedback from more experienced modelers.
The kit is by Max Factory, PLAMAX MF-57, depicting Dougram after its (spoiler alert) heroic scuttling the end of the series. Most often this scene is portrayed years later with Dougram completely oxidized and sand colored. I wanted to put Dougram in a more immediate context, shortly after the fires would have died. As you can tell from the kit (and the series), Dougram was not actually "blown up" but self-destructed more internally and remained visually intact. To that end my primary focus would be on the effects of flames on his paint and the terrain.
Test fitting, with an old die cast 1/144 Dougram to compare scale.
22-08-27-3-parts-fit-jpg.337902
The kit was beautifully molded, but for some reason the backpack cannon had a flat tip! So I drilled that out. I also (not pictured) cleaned up and scribed lines to properly separate the right forearm from the right leg where they cross.
22-08-27-14-drilling-jpg.337903
Then my first attempt at zenithal priming. It was tricky to get the model assembled without fully gluing it, as would need access to inner details later. Not the best zenithal, but it was useful as a road map for shading later.
22-08-27-16-primering-jpg.337904
Then thin washes to lay out the colors. Note most of Dougram's signature purple paint was painted in a dark silver. Washes will come later to add some purple over these areas as I wanted to show how the heat from the fire had burned most of it away.
22-08-27-24-layout-paint-jpg.337905
The base painting more-or-less complete, really more of a block-in. I would go one to refine the highlights and shadows to exaggerate contrast because of the small size of the model.
22-08-28-base-painting-8-jpg.337906
I was not happy with the slightly sculpted but smooth base. Sure, at this tiny scale we shouldn't see grains of sand because in scale they would by big rocks. And where Dougram was scuttled it was open desert, no rocks or distinctive terrain. But the base needed some sense of texture. So I experimented a little and ended up going with a mix of PVA and baking soda (with a little water) and that gave me a nice faint read of texture that I then enhanced with a couple different tan washes. The blast and fire soot was drybrushed using Muso Black. I haven't heard of people using Muso as an alternative to typical flat blacks, but I find its extra darkness reads really well as soot. You can also thin it to do washes. I used water soluble oils to add oil staining and hydraulic fluid runoff.
22-08-29-adding-sand-texture-3-jpg.337907
22-08-29-finished-base-and-assembly-1-jpg.337908
Then more refining of the paint tones, chipping, subtle heat-staining around the right side of the torso (exit of the self-destruct fire) with red and yellow inks followed by Muso drybrushing.
22-08-30-after-chipping-before-weathering-6-jpg.337909
Then weathering with Tamiya powders and more refining and touchup. A pic with Dougram finished, posing with the paints used:
22-08-30-finished-3-jpg.337910
Finished pics to follow...
gorb
Hi, and welcome to this forum.
This is a beautiful piece, very cleanly done, congrats! I like the weathering, as well as the dust that makes the unit part of its environment.
We don't see a lot of gundam / mecha around here, so this is very cool.
78 views but no opinions?
I'm kinda sad to say that this forum has been dying down for quite some time.
I don't know how many people still frequent here (specifically the Work in Progress forum), I think most people have left for other websites. It sucks, because at the time I joined there was a lot of activity, and
it was great to see so many people's awesome work, and of course to get feedback on one's own work.
Here's to hoping people come back, or that we find another forum somewhere that isn't owned by a faceless metacorporation that is trying its utter best to step on the little people in its futile quest to become tick tock.
Palantirion
- Thanks Gorb. Sorry this forum has died down. What other websites are you referring to?
